Warning [2] Undefined variable $awaitingusers - Line: 67 - File: global.php(816) : eval()'d code PHP 8.2.33 (Linux)
Warning [2] Undefined array key "style" - Line: 874 - File: global.php PHP 8.2.33 (Linux)
Warning [2] Undefined property: MyLanguage::$lang_select_default - Line: 4984 - File: inc/functions.php PHP 8.2.33 (Linux)
Warning [2] Undefined array key "additionalgroups" - Line: 6987 - File: inc/functions.php PHP 8.2.33 (Linux)
Warning [2] Undefined array key 1 - Line: 1399 - File: inc/functions.php PHP 8.2.33 (Linux)
Warning [2] Undefined array key "showimages" - Line: 167 - File: printthread.php PHP 8.2.33 (Linux)
Warning [2] Undefined array key "showvideos" - Line: 172 - File: printthread.php PHP 8.2.33 (Linux)
Warning [2] Undefined array key "action" - Line: 140 - File: inc/plugins/automedia/automedia_functions.php PHP 8.2.33 (Linux)
Warning [2] preg_match(): Compilation failed: invalid range in character class at offset 49 - Line: 28 - File: inc/plugins/automedia/mediasites/twitter.php PHP 8.2.33 (Linux)
Warning [2] Undefined array key "action" - Line: 340 - File: inc/plugins/automedia/automedia_functions.php PHP 8.2.33 (Linux)
Warning [2] Trying to access array offset on value of type null - Line: 1182 - File: inc/functions.php PHP 8.2.33 (Linux)
Warning [2] Trying to access array offset on value of type null - Line: 1188 - File: inc/functions.php PHP 8.2.33 (Linux)
Warning [2] Undefined array key 1 - Line: 783 - File: inc/class_parser.php PHP 8.2.33 (Linux)
/inc/class_parser.php 783 errorHandler->error
/inc/class_parser.php 847 postParser->mycode_parse_post_quotes
[PHP]   postParser->mycode_parse_post_quotes_callback1
/inc/class_parser.php 733 preg_replace_callback
/inc/class_parser.php 416 postParser->mycode_parse_quotes
/inc/class_parser.php 177 postParser->parse_mycode
Warning [2] Undefined array key 1 - Line: 802 - File: inc/class_parser.php PHP 8.2.33 (Linux)
/inc/class_parser.php 802 errorHandler->error
Warning [2] Undefined array key 1734 - Line: 1182 - File: inc/functions.php PHP 8.2.33 (Linux)
Warning [2] Undefined array key 1734 - Line: 1188 - File: inc/functions.php PHP 8.2.33 (Linux)
Warning [2] Undefined array key 154 - Line: 1182 - File: inc/functions.php PHP 8.2.33 (Linux)
Warning [2] Undefined array key 154 - Line: 1188 - File: inc/functions.php PHP 8.2.33 (Linux)
Warning [2] Undefined array key 1761 - Line: 1182 - File: inc/functions.php PHP 8.2.33 (Linux)
Warning [2] Undefined array key 1761 - Line: 1188 - File: inc/functions.php PHP 8.2.33 (Linux)
AP options??? - Printable Version
+--- Thread: AP options??? (/showthread.php?tid=3096)
AP options??? - A_n_i_M_a_L_ - 03-14-2007
I have mine set at 90% fuel, 50% tires, and 90% tune up, but it doesn't seem to be working... I had it at 99%, 50% and 99% too, with no luck. Anyone else having this problem.
AP options??? - TheAirMan - 03-14-2007
A_n_i_M_a_L_ Wrote:I have mine set at 90% fuel, 50% tires, and 90% tune up, but it doesn't seem to be working... I had it at 99%, 50% and 99% too, with no luck. Anyone else having this problem.
yea .. i got the same.. it will b handled tho.. just give Ray time.. :o
AP options??? - modogg85 - 03-14-2007
I dont even worry bout it. If you set up your car right then you shouldnt have to worry bout it
AP options??? - TheAirMan - 03-15-2007
modogg85 Wrote:I dont even worry bout it. If you set up your car right then you shouldnt have to worry bout it
if u say so lol..
AP options??? - modogg85 - 03-15-2007
I did say so....
AP options??? - krazyman06 - 03-16-2007
i say so too
it works just fine but u just buy fuel and ull be fine
