Warning [2] Undefined variable $awaitingusers - Line: 67 - File: global.php(816) : eval()'d code PHP 8.2.34 (Linux)
Warning [2] Undefined array key "style" - Line: 874 - File: global.php PHP 8.2.34 (Linux)
Warning [2] Undefined property: MyLanguage::$lang_select_default - Line: 4984 - File: inc/functions.php PHP 8.2.34 (Linux)
Warning [2] Undefined array key "additionalgroups" - Line: 6987 - File: inc/functions.php PHP 8.2.34 (Linux)
Warning [2] Undefined array key 1 - Line: 1399 - File: inc/functions.php PHP 8.2.34 (Linux)
Warning [2] Undefined array key "showimages" - Line: 167 - File: printthread.php PHP 8.2.34 (Linux)
Warning [2] Undefined array key "showvideos" - Line: 172 - File: printthread.php PHP 8.2.34 (Linux)
Warning [2] Undefined array key "action" - Line: 140 - File: inc/plugins/automedia/automedia_functions.php PHP 8.2.34 (Linux)
Warning [2] preg_match(): Compilation failed: invalid range in character class at offset 49 - Line: 28 - File: inc/plugins/automedia/mediasites/twitter.php PHP 8.2.34 (Linux)
Warning [2] Undefined array key "action" - Line: 340 - File: inc/plugins/automedia/automedia_functions.php PHP 8.2.34 (Linux)
Warning [2] Trying to access array offset on value of type null - Line: 1182 - File: inc/functions.php PHP 8.2.34 (Linux)
Warning [2] Trying to access array offset on value of type null - Line: 1188 - File: inc/functions.php PHP 8.2.34 (Linux)
Warning [2] Undefined array key 1956 - Line: 1182 - File: inc/functions.php PHP 8.2.34 (Linux)
Warning [2] Undefined array key 1956 - Line: 1188 - File: inc/functions.php PHP 8.2.34 (Linux)
Warning [2] Undefined array key 2222 - Line: 1182 - File: inc/functions.php PHP 8.2.34 (Linux)
Warning [2] Undefined array key 2222 - Line: 1188 - File: inc/functions.php PHP 8.2.34 (Linux)
Warning [2] Undefined array key 154 - Line: 1182 - File: inc/functions.php PHP 8.2.34 (Linux)
Warning [2] Undefined array key 154 - Line: 1188 - File: inc/functions.php PHP 8.2.34 (Linux)
Warning [2] Undefined array key 1 - Line: 783 - File: inc/class_parser.php PHP 8.2.34 (Linux)
/inc/class_parser.php 783 errorHandler->error
/inc/class_parser.php 847 postParser->mycode_parse_post_quotes
[PHP]   postParser->mycode_parse_post_quotes_callback1
/inc/class_parser.php 733 preg_replace_callback
/inc/class_parser.php 416 postParser->mycode_parse_quotes
/inc/class_parser.php 177 postParser->parse_mycode
Warning [2] Undefined array key 1 - Line: 802 - File: inc/class_parser.php PHP 8.2.34 (Linux)
/inc/class_parser.php 802 errorHandler->error
Warning [2] Undefined array key 1893 - Line: 1182 - File: inc/functions.php PHP 8.2.34 (Linux)
Warning [2] Undefined array key 1893 - Line: 1188 - File: inc/functions.php PHP 8.2.34 (Linux)
Definate fuel issue - Printable Version
+--- Thread: Definate fuel issue (/showthread.php?tid=3593)
Definate fuel issue - Inmymirror - 07-24-2007
No matter what car I have, after i fill to 50000 fuel, the first race uses about 3k worth of fuel, after that its normal, but every once in a while, another 3k fuel race?!?
Definate fuel issue - Xaero - 07-24-2007
its happening to me too. all i know is that if you have your car tuned up with all mods, and pushing lots of PR, *mine is 86x, i forgot the last number, it uses up more fuel... Sad
of course its gonna use more than a lower hp car. My problem is one race will use 3000 units of fuel and the next race will use 10 units of fuel. I believe when the person i am racing breaks down or runs out of fuel is when it happens
Definate fuel issue - fandip - 08-24-2007
I use however many units of NOS I have on each run
doesn't matter if it's 100 or 4000 it's all gone in one race
on the same note I had 6000+ units of fuel and 100 units of nos
used no nos but all my fuel units and lost the race???
[Image: 1.jpg]
[Image: 2.jpg]
Definate fuel issue - modogg85 - 08-24-2007
well you use more NOS because you have a higher level upgrade for NOS. BTW if anybody hasnt told you, that you dont need to upgrade any of your boost/nos or PnP once you hit level 14. Hope this helps you out there buddy
Definate fuel issue - fandip - 08-25-2007
how can you justify using 300 barrels in one race though? You couldn't even carry that in a vehicle.
Didn't know about the boost/nos thing thanks!
Definate fuel issue - Valorn - 08-25-2007
fandip Wrote:how can you justify using 300 barrels in one race though? You couldn't even carry that in a vehicle.
why bother gettin upgrades?????.....u run just as fast without and u dont loose as much reliability per race just get PNP and WR
