Warning [2] Undefined variable $awaitingusers - Line: 67 - File: global.php(816) : eval()'d code PHP 8.2.33 (Linux)
Warning [2] Undefined array key "style" - Line: 874 - File: global.php PHP 8.2.33 (Linux)
Warning [2] Undefined property: MyLanguage::$lang_select_default - Line: 4984 - File: inc/functions.php PHP 8.2.33 (Linux)
Warning [2] Undefined array key "additionalgroups" - Line: 6987 - File: inc/functions.php PHP 8.2.33 (Linux)
Warning [2] Undefined array key 1 - Line: 1399 - File: inc/functions.php PHP 8.2.33 (Linux)
Warning [2] Undefined array key "showimages" - Line: 167 - File: printthread.php PHP 8.2.33 (Linux)
Warning [2] Undefined array key "showvideos" - Line: 172 - File: printthread.php PHP 8.2.33 (Linux)
Warning [2] Undefined array key "action" - Line: 140 - File: inc/plugins/automedia/automedia_functions.php PHP 8.2.33 (Linux)
Warning [2] preg_match(): Compilation failed: invalid range in character class at offset 49 - Line: 28 - File: inc/plugins/automedia/mediasites/twitter.php PHP 8.2.33 (Linux)
Warning [2] Undefined array key "action" - Line: 340 - File: inc/plugins/automedia/automedia_functions.php PHP 8.2.33 (Linux)
Warning [2] Trying to access array offset on value of type null - Line: 1182 - File: inc/functions.php PHP 8.2.33 (Linux)
Warning [2] Trying to access array offset on value of type null - Line: 1188 - File: inc/functions.php PHP 8.2.33 (Linux)
Warning [2] Undefined array key 2589 - Line: 1182 - File: inc/functions.php PHP 8.2.33 (Linux)
Warning [2] Undefined array key 2589 - Line: 1188 - File: inc/functions.php PHP 8.2.33 (Linux)
Warning [2] Undefined array key 2666 - Line: 1182 - File: inc/functions.php PHP 8.2.33 (Linux)
Warning [2] Undefined array key 2666 - Line: 1188 - File: inc/functions.php PHP 8.2.33 (Linux)
IDE Question/Concern - Printable Version
+--- Thread: IDE Question/Concern (/showthread.php?tid=4774)
IDE Question/Concern - A_n_i_M_a_L__ - 12-28-2008
OK, I have never bothered with IDE before so I thought I would give it a shot.
Ok then I was at lvl 20 using cars that are obviously lvl 20 and under. R5, Corolla and a Mustang Cobra. I ran all 3 and they were all posted in the under lvl 20 area. 20 minutes later they are all gone.
So here's the question even though I was only lvl 20 when I ran all 3, do they get removed once you lvl up later on or something??? I don't get it??
Thanks for everyone's outlook on this in advance.:confused2:
IDE Question/Concern - Summit_Racing - 12-28-2008
You and your cars need to be in the same ide....
for 1-20 you cannot be over lvl 20 and same with your cars.
Well that is just it, at the time I entered these 3 cars I was only lvl 20 and so where the cars. This is what I don't get.
IDE Question/Concern - MC_Alumni - 12-28-2008
if you level up your times get droppped. My first round back i entered l evel 20 and was in first for the import, i spammed a little more leveled up and realized it took me out. unless your gonna sit at level 20, level 30, or get to le el 58+ you gotta try a lot harder to get IDE
Cool, that is what I needed to hear. Thanks Bro. I guess I have to sit back and see what lvl I am at closer to the end of the game then. :really!:
well if you stay in 1st you can realisticly get 31+ if not i would stop at 30 if your goal is IDE.
