Warning [2] Undefined variable $awaitingusers - Line: 67 - File: global.php(816) : eval()'d code PHP 8.2.34 (Linux)
Warning [2] Undefined array key "style" - Line: 874 - File: global.php PHP 8.2.34 (Linux)
Warning [2] Undefined property: MyLanguage::$lang_select_default - Line: 4984 - File: inc/functions.php PHP 8.2.34 (Linux)
Warning [2] Undefined array key "additionalgroups" - Line: 6987 - File: inc/functions.php PHP 8.2.34 (Linux)
Warning [2] Undefined array key 1 - Line: 1399 - File: inc/functions.php PHP 8.2.34 (Linux)
Warning [2] Undefined array key "showimages" - Line: 167 - File: printthread.php PHP 8.2.34 (Linux)
Warning [2] Undefined array key "showvideos" - Line: 172 - File: printthread.php PHP 8.2.34 (Linux)
Warning [2] Undefined array key "action" - Line: 140 - File: inc/plugins/automedia/automedia_functions.php PHP 8.2.34 (Linux)
Warning [2] preg_match(): Compilation failed: invalid range in character class at offset 49 - Line: 28 - File: inc/plugins/automedia/mediasites/twitter.php PHP 8.2.34 (Linux)
Warning [2] Undefined array key "action" - Line: 340 - File: inc/plugins/automedia/automedia_functions.php PHP 8.2.34 (Linux)
Warning [2] Trying to access array offset on value of type null - Line: 1182 - File: inc/functions.php PHP 8.2.34 (Linux)
Warning [2] Trying to access array offset on value of type null - Line: 1188 - File: inc/functions.php PHP 8.2.34 (Linux)
Warning [2] Undefined array key 1 - Line: 1182 - File: inc/functions.php PHP 8.2.34 (Linux)
Warning [2] Undefined array key 1 - Line: 1188 - File: inc/functions.php PHP 8.2.34 (Linux)
Warning [2] Undefined array key 1 - Line: 783 - File: inc/class_parser.php PHP 8.2.34 (Linux)
/inc/class_parser.php 783 errorHandler->error
/inc/class_parser.php 847 postParser->mycode_parse_post_quotes
[PHP]   postParser->mycode_parse_post_quotes_callback1
/inc/class_parser.php 733 preg_replace_callback
/inc/class_parser.php 416 postParser->mycode_parse_quotes
/inc/class_parser.php 177 postParser->parse_mycode
Warning [2] Undefined array key 1 - Line: 802 - File: inc/class_parser.php PHP 8.2.34 (Linux)
/inc/class_parser.php 802 errorHandler->error
Warning [2] Undefined array key 817 - Line: 1182 - File: inc/functions.php PHP 8.2.34 (Linux)
Warning [2] Undefined array key 817 - Line: 1188 - File: inc/functions.php PHP 8.2.34 (Linux)
Crew Battles - Printable Version
+--- Thread: Crew Battles (/showthread.php?tid=6072)
Crew Battles - v2pointOH - 07-15-2011
Crew battles are being set up with people that have no cars. Therefore, nothing is happening.
Crew Battles - Admin - 07-15-2011
If you have no car, that is your fault. You incur a crew LOSS if you are not in a car when the crew battle runs.
So a member of my crew was set up for a crew battle (HomiePA) and the other guy had no car, but it counted as we got the loss.
Crew Battles - v2pointOH - 07-17-2011
Admin Wrote:If you have no car, that is your fault. You incur a crew LOSS if you are not in a car when the crew battle runs.
Cres, you gotta change crew battles... People that haven't even logged in yet are getting matched up and losing..
Crew Battles - sharpie - 07-17-2011
should make it that once you buy a car it triggers your participation in the random drawing, so at the start of the round 4 out of a crew of 10 buy cars they can now be drawn to race, once the others buy their first car it puts them into the draw aswell.
Crew Battles - Admin - 07-17-2011
Thanks guys, we're working on a solution to this.
Also, are crew wins/losses supposed to stick with a player whatever crew they're in?
