	Threads: 8
		The test n' tune times are all over the board when I'm trying to tune. I can run the same settings over and over again and get full second differences in the time. This isn't how it was prior to the beta.
also, I logged in today and I have $-75,000 in my cash field. My net worth has dropped way down, and there's no history of getting HI'ed. What's going on?
	Threads: 125
		What is your login name?
What was your NW and cash prior to this happening? So you had X networth and Y cash, logged out, then logged in later and you had -$75,000?
	Threads: 8
		My login is djxero
My previous net worth was over 200k, with a little over 125k in the cash field, and now it shows -75.
	Threads: 8
		So I logged this morning, and I had $15,000 in cash. A far cry from what I originally had before I went negative. I worked my way up to about $500,000 in cash. I just raced 4 or 5 times (everyone is out of fuel) and now all of the sudden I have $-924,957.
	Threads: 125
		Xero Wrote:So I logged this morning, and I had $15,000 in cash. A far cry from what I originally had before I went negative. I worked my way up to about $500,000 in cash. I just raced 4 or 5 times (everyone is out of fuel) and now all of the sudden I have $-924,957.
You went negative cash? or networth? And it happened right after you raced someone???
	Threads: 8
		Negative cash, I assume my me went with it. I just can't understand how it would have dropped so fast and in the negative if I was racing. The I don't think any of them were actual wins or losses.
	Threads: 125
		Xero Wrote:Negative cash, I assume my me went with it. I just can't understand how it would have dropped so fast and in the negative if I was racing. The I don't think any of them were actual wins or losses.
I'm confused.. so you were positive cash, raced someone, then had negative cash?
	Threads: 8
		That's right. I raced someone and then I looked up and was in the negative.
	Threads: 43
		there is risks involved in racing. if u raced some1 and lost this could be why
**edit**
if this is the case this should be fixed to where u cant race ppl that u cant cover the risk of the race
	Threads: 125
		LarryG Wrote:there is risks involved in racing. if u raced some1 and lost this could be why
**edit**
Correct... I believe this is what was happening. Fixed.
