dyno tune
ok well dyno on mc seems to be different to me i cant get it rite any pointers cant get then high to even out
the way ive always done it is set all values to mind 70's or low 80's ...
then use the line on the graph to determin what need to go up or down ..
adding values to the numbers lowers the bar ... so taking them away lowers it ... simply add or subtracted number from the entered values to make the bar a stright line.
then you will have a over all % of power output ... once its in a stright line (the line on the graph) move all number up or down one or 2 number so the lines stays stright but moves up and down onthe graph until the % of the power output is close to 99%.. usaly it will hit 99.3% or something rather ...
to get it to 100% you will have to play around with the spark plug gap.. usaly lowering it will get ya there ..
sorry in a rush could explne it better but hope this helps ... catch me online chat and ill sort ya out.
One Of Midnites Forum Mod Team......Black__Metal ™©
couldn't have said it better myself
well its not complicated whense u get the hang of it
u gotta make sure its at 13.5 if the car fully built with out turbo/supercharger
and i think 13.2 with turbo not sure havent tested
spark plug gap should be at 0.032 to 0.040
Make Sure it says 100 percent tuned Big Grin
[Image: untitled.jpg]
"[email protected]"
Msn- "[email protected]"
Hit me up Noob:postwhore::postwhore:
i find a number thats already where it should be in line,set every box to that number,then adjust the extra 1-3 up/down it needs. then do the spark plug gap. usualy around .030
[Image: 53369.png]
I am teh Fail Frcg Big Grin
ty every one for the help
everyone does it diffrnt ...
im bored ....should right up a guide but meh.
and every car is diffrnt so when you got one set of numbers copying them and using them will not work ...
  dyno tune percentage LarryG 2 1,175 02-23-2010, 08:48 AM
Last Post: Admin
  New Dyno Tune Benton08 7 2,029 08-28-2009, 05:33 PM
Last Post: Benton08
  MC's new dyno! Admin 21 3,904 12-22-2008, 08:13 PM
Last Post: LuDe
  new dyno? xkuza 3 1,199 10-30-2007, 04:48 PM
Last Post: liGHts_OUt_spEEd
  CANT TEST AND TUNE Jdodge73chargerh 5 1,448 12-14-2005, 10:56 AM
Last Post: str8vi3tcuhz
  Test n' Tune kookookachoo 14 3,156 12-13-2005, 11:19 PM
Last Post: bscar
  Can't Dyno ronron2112 2 1,202 12-13-2005, 03:02 PM
Last Post: monteman
  can someone help me tune my cars i have asked and not very m LoveDontHate 24 4,884 11-27-2005, 11:28 PM
Last Post: LuDe
  Test n Tune Issues gsg9mark 6 1,686 11-20-2005, 02:02 PM
Last Post: Black__Metal
  help cant tune mrmitch555 12 2,853 10-21-2005, 12:50 AM
Last Post: modogg85
1 Guest(s)
